sarabande
Doing some work on the "stack effect" for the unpowered transport of contaminated hot air from low Point A to high Point B, so I wondered...
There's lots of concerns about keeping fresh air circulating in the boat, so if you have a keel stepped mast, has anyone tried cutting a hole in the mast near the cabin floor, and seeing if the various holes for sheaves, etc, at the top of the mast act as extraction sources ?
It's not so much a true stack effect, which relies on a pressure differential (won't be much even over a 40ft mast) but the air in the top section gets heated, rises, escapes through sheave boxes etc, and sucks up air from the base. Hypothesis !
