andyball
While repairing the heads on a friends boat (nauticat 44)....noted that 'tho the installation is below the waterline, no vented loops/anti-siphon valves are fitted, just a loop well above the waterline.
Jabsco's instructions are clear: you must have an anti-siphon valve in both inlet & outlet if below waterline.
Everyone I ask in person says there's no need-just make sure there's a loop above the w/l.
I can see that in the event of a major problem with the toilet pump/valves, AND the seacocks being left open....(most likely,knowing the boat/owner) the valves might be necessary.
Anyone got an opinion?...are the vented loops o.t.t. in this case, as local "experts" claim?, or vital equipment?.
Concerns are 1: finding room to fit the b.things, & 2: will the one on the outlet not clog up (thus not doing it's job), or smell somewhat?.
TVM for all advice
TVM for all advice
