nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
... I've bought enough sapele veneer to do the whole panel if necessary. I will need to patch the panel, and ideally remove the existing veneer...
I've patched the large holes and removed the veneer from the panel, using a belt sander followed by hand sanding. As expected, there are a couple of areas that need filling, either where there was a hole, or a slight depression on an edge caused by the sander.
I'm using iron-on veneer, rather than the hot-melt film I discovered (http://amzn.to/1wT3cgN) but I imagine the result will be similar.
I'm not sure what to fill and level the substrate with. Any suggestions?
