D
Deleted User YDKXO
Some of you will know that the Med boats are subject to very aggressive fouling of exposed sterngear and bowthruster parts. Its common for boats to lose several knots of speed in only a few weeks during Spring and Summer. I have tried PropSpeed in the past with no success and I had resigned myself to using the services of a diver 3-4 times per season to keep my sterngear clean. This year, I tried a new treatment http://www.marlinpaint.com/EN_MARLINPAINT_HOME.html which another forumite, Hurricane, found. This was applied to the sterngear on my boat at the end of April this year. Unlike Hurricane who took his boat on an extended cruise after applying the Velox Plus treatment and found that the treatment did not properly adhere to his sterngear, my boat sat in the marina for most of the period since the treatment was applied with only a few short trips out. In my case, the paint did adhere quite well to most surfaces in the 2 1/2 months since it was applied but the boat was still 3-4 knots down on speed last week. On inspection, it appeared that barnacles had attached themselves to even paint covered parts so it appears that, in my case, adherence of the paint wasn't a problem but the antifouling properties of the paint itself were. The fouling was probably not as bad as it would have been had Velox Plus not been applied at all so I have to say that it was partially successful but, disappointingly, not the solution that I was hoping for
