Ardenfour
Below is a photo of the VDO mast head unit. The square section plastic spindle in the centre of the photo accepts the wind direction vane, which has a square hole underside, and held on with a set screw. A closer look will reveal a crack in this spindle, so the screw won't remain tight as the square bit splays.
So, how to repair this spindle? My thoughts were, weld the crack with a soldering iron, but the wall thickness at the crack is very thin. Bind the square spindle with terylene thread then epoxy, much in the way fishing rod rings are attached. I would then have to enlarge the windvane hole to fit.
Any other ideas?View attachment 54303
