noswellplease
Being totally new to the varnishing game I plan to replace some of the teak toe rail and basically varnish the lot. I also plan to replace the cabin double door entrace with new teak doors and varnish this also. From what I can gleam here I start with a coarse say 120 to get back to the wood. Then apply the first coat. Then I guss I use a slightly finer grade paper. Is the wet paper to provide the final clean up before the next coat goes on? I'm guessing this is the case. If I want to get a really nice look do I have to apply about 6 or more coats? . Finally the old cabin doors have air slots built in which take a bit of doing for the joiner. Are these really necessary? or could a series of drilled holes do the same job without all the trouble. I know it would not look quite as nice, but I'm just wondering is it really necessary in the first place. If a few pointers can be passed on about these it would be much appreciated. Thanks.
