Varnishing in the tropics.
john_morris_uk
3 Jul 2002
At sea somewhere.
We’re trying to do a few odd bits of varnishing. Our chosen poison is a two pack system that’s mixed 10:1
The problem is that it’s 30C day or night. The varnish barely has time to ‘flow’ and brushing it out is impossible. Lay it on and one or two strokes before it starts going off is all you get. You have to work REALLY quickly.
The only upside is that yesterday I got three coats on (all that’s required) in an hour or so.
Would less catalyst slow things down? How critical is the 10:1 that’s specified?
Humblebee
10 Nov 2001
Muchalls
Have you asked Morrells? Some paints can have retardants added to slow down hardening, perhaps there is a product which will do exactly what you want.
(Thread drift - in my quarrying days we used to add creosote to tar if it was being laid by hand. This greatly retarded the time it took to harden.)
justanothersailboat
2 Aug 2021
ah! Cellulose lacquer. Not what I was thinking of when I first read "varnish".
It's meant to set super fast, you can do 3 coats in just a couple of hours even at ten degrees. It's not like varnishes. If brushing Morrells lacquer you need to thin it a bit more than if spraying. Even on a relatively cold day I found that it didn't brush out super well without the allowed extra 10% thinners by volume (though I was using 440, not 450, I think they're very close). I suspect you could add a bit more than the specified maximum of extra thinners in those temperatures. Any cellulose thinners will do if you're running out of Morrells own.
I would be more worried about humidity, the surface can go a bit sad if there is condensation, though maybe it's too hot for condensation...
john_morris_uk
3 Jul 2002
At sea somewhere.
No problem with condensation. I didn’t know about thinners. I’ll try and find some cellulose thinners as you suggest. Not always easy when you’ve mostly only got shanks pony on a Caribbean island. (I’m not looking for sympathy!!)
Thank you.
justanothersailboat
2 Aug 2021
Good luck! I can imagine getting specific products must be tricky there, but I hope cellulose thinners are common/generic enough that you have a good chance. They might be being sold for use with cellulose sanding sealer rather than lacquers. No idea about the Caribbean I'm afraid, but elsewhere cellulose lacquers are becoming less common (more use of polyurethanes) but cellulose sanding sealer is still fairly available. that was what made me think to mention it.
john_morris_uk
3 Jul 2002
At sea somewhere.
Is it still used in car body repair shops? That’s where I first came across it.
