sailorman
It doesn't matter what wood it is really Simon especially if its solid. Sanding if you have the thickness will eventually get you to virgin wood. Good luck!
By the way what I didn't say was that all wood darkens when subjected to UV. Light sanding often gives you light patches and dark patches because you are breaking through the UV affected surface. If you have the thickness don't "tickle" it. Use a course grit paper and take the surface off removing up to 1mm material if necessary, then reduce the grit until you remove al scratch marks. I have just done an area on my boat (complete refit on a new to me boat) Started with 60 grit and followed with 80, 100 and finally 120 by machine before one coat of 50/50 varnish. Then when hard 120 again but this time by hand using a wood block to "flat" down, (sand with the grain when finishing) followed by 4 coats of gloss with 10% thinners, then flat down again and give a final 2 coats of ready rubbed (matt) The result is superb but it takes hours of patience!!
Not forgetting to warm the varnish in a kettle of hot water before use to thin without thinners therefore keeping a fuller bodied product
