narcer
Reading the recent posts about which is the best varnish and how to apply etc , maybe this might help those who are undecided.
Just finished a 3 month project restoring two 18m Sidka Spruce spars from a schooner here on Mallorca. I was thinking of trying Xtiffers very good method with the Epoxy Impreg but the owner had his own ideas and decided for traditional tung-oil varnish and we went with Awlgrip Awlspar HS, finished with Awlspar classic. After acid treatment and 15 coats (with the same badger hair brush) what a result ! This varnish is the real deal.
Some of you maybe familiar with a certain method of prep - we use it a lot in the trade. This method involves wet-sanding linseed oil into the grain of the prepared wood, repeating this maybe 7 times. You then varnish over this linseed oil base and eventually you get an incredible 3-D effect within the varnish from the grain (esp mahogany). However the Awlspar High Solids varnish from Awlgrip gives you this 3-D effect without wet-sanding the oil in with p400.
I´ve attatched some pics just to give you an idea of the difference "before" and "after"...
http://www.ybw.com/forums/attachment.php?attachmentid=7442&stc=1&d=1286388452
http://whttp://www.ybw.com/forums/a...ment.php?attachmentid=7443&stc=1&d=1286388452
