SABREMAN
Active Member
Went to check the clearances today, being the first time I've got to do this and after wrestling the cover off checked the manual for the actual measurement. According to the manual , assembly para 14, the clearance should be 0.30mm (0.01181in) OK but in the tech data at the back the clearance should be a max of 0.15mm (0.00590in). Gulp, which is correct? I suspect the 0.30 but can anybody confirm this? Thanks in advance.
