Vacuum extraction pumps
Poignard
23 Jul 2005
South London
I had one very similar. It worked fine. My only complaint is the amount of space it took up. It's capacity was 6 litres and my engine only held 1.75 litres so a 2 litre pump, had I been able to find one, would have saved some space.
If there were to be a next time, which there won't be, I would buy a little 12v pump and discharge the old oil into one of many old containers you find lying around the waste oil tank in the boat yard.
Boathook
5 Oct 2001
Surrey & boat in Dorset.
I saw some 2 litre ones on ebay or amazon today when I was looking for a bit of kit to pump oil into a Honda outboard gearbox.
38mess
9 Apr 2019
All over the shop
Update.
I gave my brass pump another try, I must have been doing something wrong last time I tried. It pumped the 3.5 ltrsof oil out in less than 5 minutes this time.
Refueler
13 Sep 2008
Far away from hooray henrys
The 6 ltr Spherical are usually the small Pela ... I use one for literally anything to get out .. last bit of water in bilge .. oil .... gunge out of fuel tanks ... etc.
I now also have a Lidl electric pump .. its ok - but the Pela is better ...
Tip : After time - the spring metal pipe - the outer plastic cover fails in places .... what to do ? You can buy a new pipe I suppose ...
or
Heat shrink tube ... slide onto pipe after trimming smooth the failed area plastic .. cover the failed area and then shrink tight. Bingo - no leaks .
38mess
9 Apr 2019
All over the shop
or
I was surprised at how well this little brass pump worked. Had to wear a glove because it got pretty hot.
If it didn't work I was getting the Pela rip off from F4
