oldgit
Grandad ...................the toilet will not flush.
Halfway through the boating holiday, seven people aboard and one of the hottest days of the year.
Lifting the lid reveals a bowl fill to the brim.
A small paper cup solves the problem of emptying the " bowl" to expose the flush cap.
Depressing the little foot pedal reveals the chamber below and the usual firm poke with the bog brush achieves nothing what so ever.
Nothing else to do but carefully put a hand into the maw of the bog and discover .............................................
One of those little plastic ice cubes, big enough to block the hole but not big enough to be sucked through.
Problem sorted ..?
You joke of course, this a boat we are talking about.
The pump has just spent the previous hour or two attempting to develop sufficent vacuum to pull the little ice cube into the holding tank and split. No vacuum .
Getting to the pump involves emptying an awkward to get at locker under the front bed.
Dismantling the vacuum pump reveals a smelly sticky gooey mess around the bellows, which had decided to call it a day.
Managed to borrow a Porta Pottie which reminded me of everything one wished to forget about the early days of boating.
A solution.
Went onto the website of the UK agent to discover a replacement bellows would cost £180.00 plus 2 pairs of Duckbill Valves @ £47.00 per pair.! Just under £300.00 ?
The actual solution. Ebay. Repair kit with all the above £65.00. Delivered free in 5 days.
Appears to be fairly heavy duty robust pieces of kit, despite dire Youtube warnings of flimsy chinese rubbish.
Then the 40L calorifier failed.
Long grumbling posts regarding impossible to lift out leisure batteries and impossible to remove/ replace calorifiers, available on request.
The size of the connections on the old and new QUICK calorifiers are totally different despite deliberately choosing to purchase the more expensive Quick replacement to make life easy.
Problem sorted ..?
A solution.
