V8 Running problems
spike2450
13 May 2007
Falmouth, Cornwall
Hi all
I have a 1998 5.0l v8 with thunderbolt 5 ignition, It starts and runs fine for about 10 to 15 seconds and then cuts out, it does the same whatever the throttle/revs are. It idles at 600 rpm. It doesn't restart straight away, i was thinking fuel and therfore changed the fuel sepaerating filter but she still consistently dies. Any help would be great.
Have you checked the oil pressure switch that goes to the fuel pump ?
You have an a oil pressure sender that goes to the guage on the dash, but also you a seperate switch that goes to the fuel pump, idea being that it wont pump fuel if the oil pressure is low, it will only give you 15-20 seconds of running which seems to be what you are getting. I have heard its a common problem, easy to test just jump the wires on the switch and see if it cures the problem.
