UV resistant spray hood windows
Wife of Lofticus
23 Nov 2010
Finike, Turkey
Current windows in our spray hood are milky and unusable. Looking to get them replaced and local, well recommended sailmaker, in Finike,has given me a piece of his window material.
Lofticus is concerned it is too thin.
Two questions:
Does thickness directly relate to UV stability?
Wouldn't thinner, more flexible plastic wear better in a sprayhood that is up and down quite a bit especially in the spring/ summer season?
Expertise sought before Lofticus commits!
23 Jul 2012
You need a material called "Vybak". I have just had a front screen made with it for our bimini. I had to import it myself for the cover maker in Corfu. Neither he nor his father had seen it before but i think they will now offer it as a "deluxe" alternative to all their customers. I have, in my garage a 1973 MG which has the original hood made with Vybak and it is clear as crystal.
You can obtain it here:-
http://www.woolies-trim.co.uk/p-1880-vybak-large-sheet.aspx
Tradewinds
12 Jan 2003
Suffolk
www.laurelberrystudio.com
Oyster spec it for their covers. on or two of those do manage to get greater distances than me, although i dont employ a skipper to do deliveries
I went for Kayospruce sheet material Kayo-Glass. Stratoglass was double the price. Regret it now as the Kayo-Glass has a bluish look and is not as crystal clear as a plate-polished PVC should be.
In fact, SC's recommendation of Vybak is a very good one - a really high quality plate-polished (pressed at high pressure) sheet (not calendared) PVC.
Wife of Lofticus
23 Nov 2010
Finike, Turkey
Thanks for suggestions of products to use, can be challenging to import into Turkey I believe, unless anyone can tell me an easy route!
Was curious to know if there is a relationship between thickness and UV resistance?
Nostrodamus
7 Mar 2011
www.cygnus3.com
Just replaced them on our Oyster as they became impossible to see through. Sun does make a difference but they have to be washed each time you take the boat out. A sail maker suggested to me to use lamp oil but that did not sound right to me.
I knew i needed some more so I had nothing to loose by seeing what may clean them. On really badly worn ones you can use something like t cut to get a lot of grime off but it is a last resort weapon of mass destruction.
sailorman
21 May 2003
Here or thertemp ashore
Read the cleaning instructions on #2 link
who made your hood
