Using VHB double-sided tape for installing Perspex windows
Mark G
Active Member
14 Oct 2009
Has anyone used VHB (very high bond) double-sided tape for installing Perspex windows instead of fasteners?
Yes.
Although I used polycarbonate for the glazing, not Perspex.
I was attracted to omitting fasteners as they are the cause of failure.
On advice from an Australian website I used 2.5mm VHB instead of the normally available 1.5mm which allows for greater contraction and expansion of the glazing. The VHB went inside butyl tape.
Before fitting I sprayed the inside of the glazing with high temperature matt black paint to hide the VHB and butyl, using the protective film as a mask.
The tricky part was offering up the glazing because once the VHB makes contact it is stuck fast.
I did ten windows in July this year and so far none have come away and all are watertight.
Next job will be to repeat the exercise on my companionway hatch which is cracking up around the steel fasteners.
