Anthony
Hi,
The clears on my sports cruiser are shot again after 4 years, going brittle and stopped being see thru a while ago (just the clear windows, the fabric around them and roof are fine) despite vary careful handling, cleaning and polishing with the correct products etc (we get a lot of UV here in Australia).
The cost of the clear plastic alone is very expensive before you get into the labour cost or effort to sew it in, just to expect it to start to degrade again in again in a few years. So I was wondering, why don't we use clear plexiglass / acrylic for these window, which is cheaper, and easier to clean, and that sort of plastic in hatches etc seems to last a lot longer than the flexible plastic used for clears?
Ok so you cant just sew it in to the cover panels as you can the clear flexible material, but I am wondering about bonding a strip of material around the edges of it and then sew that material in; has anyone ever tried it? Of course on curved areas in the front the rigid flat pieces wont work, but there are a lot of flat pieces on the sides and rear where it potentially could be used, could even apply tint film to it to keep the uv and heat down inside.
Practical idea or ramblings of someone driven to desperation by repeatedly spending $$$ on a solution you know will fail again very soon...?
Ants
Ants
