jwdorst
Active Member
I have received a quotation from a reputable yard to replace my worn teak side decks (lying on GRP) by a layer of flow coat (ie gelcoat with wax added in order to ensure the coat sets) mixed with some form of anti slip material. A bit like anti slip paint I suppose, but more permanent.
Has anyone on the forum any experience with this anti slip solution? Will flow coat adhere to old GRP well enough to withstand inevitable local flexing of the deck. Is flow coat really tougher than paint? How much flow coat would be needed to cover 10 square meters (= approx 100 square feet)? What is the going rate for flow coat in this kind of quantity? I believe it is relatively cheap.
The yard has quoted 3400 euros (= approx 3000 Sterling) to supply and apply the flow coat. I would have to remove the existing teak decks myself and prepare the underlying GRP. At 60 pounds per man hour, after subtracting the cost of the flow coat (?) it seems to me that they are calculating an inordinate amount of man hours for the job. But then perhaps I don't fully appreciate the complexity of the task in hand.
The boat is a Bavaria 390 and we are talking about side decks and fore deck only.
All comments appreciated.
JW
JW
