use of IPAD as back up for navigation
wieland
New Member
10 Apr 2012
Ipswich uk
did I miss something???
In a very recent issue of PBO the use of an IPAD was discussed as a very useful back up tool for navigation. The pros and cons of the various available navigation Aps were discussed.
I went to talk about this with a couple of staff at the Apple store in Cambridge today.
Conclusion: These Aps cannot really work at all when you are out at sea,i.e. off shore, because the signal for the 3G IPad GPS comes from terrestial telephone masts and not from a Satelite. The IPad will therefore be only useful for navigation, when you sail on rivers or very close inshore.
Why was this not mentioned in the PBO articles? Or did I get something wrong here?
Anybody knows the answer????
Yep - your entire first sentence is completely wrong :)
The iPad GPS has nothing to do with telephone masts, and works exactly like a boat GPS.
Just make sure you don't buy the cheaper Wifi-only iPad, because it's intended for use mostly at home and doesn't have a GPS in it.
Apparently you could get a bluetooth GPS for the Wifi only iPads - but prob not as convenient ...
3g iPad & iPhone work fine independently of the phone network - as proven by many on here. There is an advantage of having a phone signal in the first instance as it gives a rough position - also I think there's some data feed about Satellite timings that can get passed more quickly - but not sure... eitherway - phone signal helps get the position more quickly - but it will work without.
Conclusion: These Aps cannot really work at all when you are out at sea,i.e. off shore, because the signal for the 3G IPad GPS comes from terrestial telephone masts and not from a Satelite...
Strange, the Apple Store people normally know what they are talking about ...
Sounds good to me, how far offshore are you going? I "usually" get a signal about 5nm out to sea.
Personally I use a chart 95% of the time, but I am very old. No issue with signals there.
My last trip away from the coast I could still get a signal and post on here about 15Nm off ... :) was a bit slow though ... (posting - not the boat!)
If you're thinking of using phones for navigation I have to commend Motorola for producing a truly waterproof gps smart phone the Defy. With Navionics we could navigate at speed in some fairly trecherous waters off Brittany as well as if not better than boats equiped with dedicated marine plotters.
It was submerged many times to around 2m at speeds of impact in excess of 22 knts, we were cat racing up to 15nm offshore.
I used my iPad as a back up to navigation. In this case I had to cross a sand bank with the aid of a transit between 2 telephone masts, then find a contour line, follow it until I found a pool as well as using 3 point fixes. The iPad allowed me to back up the tradition methods giving me reassurance I was doing it all right.
Now time for the plug :D I have a wi-fi model and the kind people at bad-elf sponsored me a bad elf gps unit which is a gps dongle for the iPad, iPhone & iPod. find out more here
The image of my Track.
