C08
Advice from outboard manufacturer about use of E10
"If the use of gasoline containing alcohol is inevitable, or presence of alcohol is suspected in the gasoline, it is recommended to add a filter that has water separating capability, and check the fuel system for leaks and mechanical parts for corrosion and abnormal wear more frequently.
And, in case any of such abnormality is found, discontinue the use of such gasoline and contact our dealer immediately. Damages resulting from the use of gasolines that contain alcohol are not covered under the limited warranty".
This only deals with problems with corrosion but problems with fuel pipes and seals may be encountered.
