alant
Why do they have 2 for each engine, rather than the combined version we enjoy over here?
But they don't, actually.Why do they have 2 for each engine, rather than the combined version we enjoy over here?
MapisM;5890712[B said:]But they don't, actually.[/B]
I can't think of any boat either side of the Pond, equipped with electronically controlled engines and with separate throttle/gear levers.
Otoh, if you are talking of boats powered by mechanical engines, separate levers were quite popular also around here.
With modern boats/electronic engines, the only exception to single lever installations is with extremely fast boats, which due to the way you must be able to play with the throttle levers it would be crazy to install single levers.
Seen them more on Sports boats .
Seen them on Rings and Huntons
As others have said it makes marina movements a doddle, leave the throttle and just move in and out of gear.
http://www.martinpaynemarine.com/used-boat?BoatID=3615100&desc=3615100 - Hunton RS43
I must say I don't get the marina point. you can just as easily flick a single lever to make a marina manoeuvre, surely. No big deal though.Seen them more on Sports boats .
Love your boat - I just clicked on your link. I drove the black RS43 called Speedbird, built 2015, in South of France - belongs to a friend. Awesome boat. (Twin yanmars)
Ahem, who didn't? Your OP seemed meant to generalize between "us and them", so to speak, regardless of the engines age/type.You'd best explain that statement, who mentioned "electronically controlled engines"?
Also what about the vetus controls I well remember back 20 yrs ago, they were 'fly by wire'.
Agreed.I must say I don't get the marina point. you can just as easily flick a single lever to make a marina manoeuvre, surely. No big deal though.
Possible eeek ? I always understood that revs should be at tickover to change from ahead to astern. Crash stops and changes lead to embarrassment and damage.
Electronic engines are the overwhelming majority in any boat built in this millenium, and they practically imply single lever controls - either sides of the Pond.
Otoh, if we should generalize, I tend to agree that electronic throttles on mechanical engines (through electronic actuators, eventually connected to the engines with cables anyway) were probably a bit more popular in EU than in the US.
If this was the sense of your question, I would put the reason down to US boaters being a more practical and less fussy bunch than we are.
In fact, fitting electronic throttles to mechanical engines is a solution to a problem that doesn't exist - and introducing a new potential problem in the process!
