Firefly211
A couple of weeks ago the pump on the Jabsco was becoming stiff so I stripped it down an renewed the rubbers. What was clear was that there was a lot of uric acid crystals in and around the seals and the bores of the pump base. Suspecting the worst I cleared and rinsed the holding tank this morning to find more solid crystals in the tank. I am guessing the pipes are going to be coated too.
I regularly use Thetford Aquachem as I thought this minimised this sort of thing. I also put some in the loo brush container so that it also has regular doses when the brush is used.
Q - Is there any easy chem solution to flushing out the system and what can I use to stop this happening?
