Boo2
Hi,
My engine installation has been running for 2 1/2 years and marches from one engineering cock up to another :
Firstly the original single lever Morse controller (see pic below - not my boat) is deemed to be unusable. It worked fine in the old engine installation but for some reason, not fully understood to me, it cannot be used with the new Nanni engine because the throttle engagement cannot be delayed for long enough after the gear engagement. The engineer says "it's worn".
Just now the engineer phones up and says that the replacement he's ordered in is too long to fit the recess in the cockpit which it's mounted in. This is after he's cut the mounting hole in the recess to fit the new control ! He can't cut the handle of the new controller shorter because the neutral engagement button is on the end.
So I urgently need a Morse engine control that has a handle shorter than 8" long. And ideally with a pull-for-neutral button that is not mounted on the end of the handle.
Any suggestions will be received with abject gratitude,
Boo2
The following picture is not from my boat but is the identical model of control. My boat has the control handle fitted in a recessed niche in the cockpit hence the size limitation.
Boo2
