BobnLesley
We have a Yanmar 3GM30F and traditional propeller and shaft gearbox fitted; the engine starts and runs perfectly and reverse gear is equally good, but when we engage forward, we have a problem: At tickover it too is OK, but once we start to build-up the revs 50% of the time it works fine, but on the other half we get a shuddering vibration (to varying degrees) as the revs increase until about 16-1700rpm, whereafter it's OK again?
It's not a new problem, but having just relaunched - new cutlass bearing installed and stuffing box re-packed - it seems to have worsened from an occasional irritation to a serious danger; the worst incidents of shudder/vibration are much worse and all we can do is return to neutral and re-engage repeatedly, until we get a relatively smooth speed pick-up, a real pants-browner this morning as we were holding-off awaiting a lifting bridge in a 2 knot tide!
I can't see any problem with the gearbox/shaft connection, there's nothing around the prop or shaft itself and the engine mounts all look OK; any ideas?
