Brookey
New Member
I'am currently reffiting for an extended time cruising, hoping to get to the caribbean but no rush or fixed plans but my mind has turned to upgrading my instruments.
I have decided I will probably purchase a Raymarine c95 MFD and Radar as at present I have no radar and my Plotter is a bit tired. However to keep costs down I would like to keep my Clipper wind, speed, depth, ( I know maybe not the best but they work and I find the diplays clear and simple) and my Raymarine st6002 / smartpilot autopilot.
I was thinking the radar will simply plug into the MFD but that I will then need to buy an NMEA multiplexer so I can put the Clipper instruments into the MFD and then use a seatalk to seatalkNG converter to connect the autopilot, this would then leave me a spare NMEA am I thinking along the right lines. Does anyone know also if I connect the autopilot in this way wether I wll be able to control the autopilot from the MFD, believe this would be possible with a true seatalkNG sytem but not sure with the converted one.
Thanking you in advance
