Upgrade Raymarine T901 speed log transducer
DaveyG
Active Member
10 May 2016
Thinking of upgrading my Tacktik (raymarine) T901 paddlewheel log to a no moving part version like' Airmar DST810 Smart Transducer'.
Has anyone done this, do I need to replace the thru hull housing (and liftout) ? and does it easily interface to the existing tacktic display ?
Are there other / better transducers to use ?
Thanks, Dave
The DST810 is a retired Airmar product that has a conventional moving paddlewheel...
https://www.airmar.com/Product/DST810
Airmar makes a non moving part speed transducer...
https://www.airmar.com/Catalog/Marine/Speed-Temperature/DX900P-2000
It won't interface directly with your current Tacktick hull interface or wireless displays because it outputs Bluetooth and NMEA0183. To connect to your Tacktick wireless displays you would need a Tacktick T122 if you don't have one already.
Almost no Tacktick equipment is available new now as Raymarine have retired almost the whole product range (the compass remains). You can buy a T122 used on ebay still. I would not recommend spending money on an obsolete system.
I don't know if the transducer would fit your existing through-hull but Airmar makes all Raymarine log transducers including the former Tacktick one so Airmar will know.
