Colvic Watson
This isolator receives charge from the alternator and sends it to the house bank, starter and thruster batteries. To save having three chargers and because the thruster battery is otherwise always left depleted after arriving in the marina, I wanted to connect the charger to it. The data sheet says it's fine to connect a charger but an alternator and a charger? My worry is that I will quite often start the engine with shore power connected and so the charger will running, no way will I always remember to switch it off - I just need to reassure myself that that won't damage the alternator connected to the same stud? I'm assuming not because often alternators and battery chargers are often connected to the same battery terminal and chargers are often left on when the engine has started?
Apologies to the helpful posters on my earlier thread where I'd called it the wrong thing
data sheet: http://www.es-store.co.uk/user/uploads/Datasheet%20-%20Argo%20Fet%20Battery%20Isolators%20with%20alternator%20energize%20input%20-%20rev%2001%20-%20EN.pdf
