I appreciate that semi flexible solar panels are typically glued and screwed down onto a deck or cabin top however I am mulling over an edge case mounting option.
Given a 50w panel measuring 100cm x 28cm. If this was supported around its whole outer border on a 1" lip would the unsupported middle section sag or flex to a damaging degree if a little wind caught the underside? There would be zero risk of someone stepping on the panel.
