[/ QUOTE ] I think I'd prefer to stick to solid timber but if I was using ply I would cut "on the diagonal". That overcomes the problem of half the plies having the grain in the wrong direction.
I'd be interested in expert opinion on the idea though.
The rudder on my boat is made up from 3 pieces of 6" by 2" mahogany. I always thought that the reason was that timber 18" by 2" would be very expensive and difficult to source. By laminating several piece of timber together produced a more stable component less likely to distort is split.
i have used this stuff at home, very useful for a curve but i wouldent like to rely on is for strength, virtualy all the laminations run in one direction with just 1 or 2 very thin ones at right angles to hold it together
I think what you are talking about is plywood with laminas running at 45degrees to each other instead of 90. This makes it considerably stiffer in one direction than the other, but retains the stability, flatness and accurate finished thickness ply has compared with solid timber. It is not 'bendy' plywood used for tight curves, quite the opposite in fact.
If you use it to make a rudder or centre board it would be oriented so that the grain direction runs 22 1/2 degrees from the vertical (ie half of 45).
Although I have seen it referred to in a number of books and magazines about boat building I have to confess I have never used it or even seen it for sale. As another poster mentions, Robbins is the place to go, though I had a quick look and couldn't find it on their web site.
Going back some 30+ years, I seem to recollect this material being sometimes specified for sailing dinghy centreboards, where the bending load is quite severe in the one direction. It had more veneers running in the "lengthways" direction. I don't think that, in practice, it had any real advantage over a good piece of solid timber. If there are still builders of wooden racing dinghies about, they might help.
