srah1953
I remember some time ago in a post a recommendation to put unhardened epoxy around a new deck fitting. What does the the unhardened epoxy do? Does bit eventually harden?
The epoxy hardener works by bonding to the resin at a molecular level. If you put insufficient hardener in then the resin molecules that don't have any hardener molecules to bond to will remain liquid permanently and you end up with a weak rubbery compound that is no use to man nor beast.No, I don't remember it and cannot understand it. Epoxy with no hardener at all will never harden, it will remain a sticky liquid. Epoxy with insufficient hardener may go hard eventually but I see little point in taking a chance on it. Far better to bed fittings on a suitable sealant, there is a wide range to pick from. Poyurethanes (Sikaflex, etc) have been widely used but the new hybrid polymers are gaining ground. Butyl offers some advantages, such as not setting.
