jamie langstone
My MF805 is get it antifoul removed to the gel coat and i require a good primer so any reccomendations.
ThanksGelshield 200
Primers
Gelshield 200 is a quick drying and easy to apply epoxy primer, that protects GRP against osmosis. You can use it down to just 5°C and as it’s fast drying, you can apply multiple coats in one day.
The above is from International Paints website
looked at primocon and there is no mention about it can be used for GRP. This is the what i lifted from the international web site
(Primocon is a fast drying, one-part primer for use below the water line before antifouling is applied. Formulated for timber, steel, aluminium, cast iron keels and lead keels.)
Primocon would act as a tie coat to tie anti-fouling to a bare GRP hull but would not be any use in preventing osmosis.
