baylabayla3288
I'm concidering converting the exhaust system on my Fairline Phantom 38 with TAMD63ps to exit under water. I would be interested in your views on how to realize this without cutting too much in the boat. Adding external boots would not be a good solution as they would be sticking out too much and prone to get damaged easily. The exhaust outlet openings are situated at the rear corners on the Phantom just above the waterline at rest. I would be interested to see picures on how the underwater exhaust on a sealine 43 is built. It looks like there is a box type of solution running outside the hull. The reason I'm interested in this is because of some disturbing exhaust resonance on the fybridge at certain speeds and possible getting less soot on the transom. Thanks in advance for your views.
