Tranona
It is not possible to answer your question without knowing the actual alloy used in your rudders. The brass types such as manganese bronze (which is commonly used for P brackets) have high zinc contents and will dezincify. However, isolating from seawater as described in this thread can reduce or eliminate dezincification. Other alloys do not and will not suffer from galvanic corrosion on their own, but may do if mixed with other metals. So, I think the answer is that there is no clear answer.I was wondering about protecting bronze rudders by coating in epoxy and anti fouling over the top. But I was told this would concentrate galvanic action on the tiny gap on the shaft where the rudder enters the hull, as this must remain uncoated if the rudder is still to move easily. Is this true?
If coating works to help prevent galvanic action, should the covered parts still be connected to a separate anode in the normal way - just to be on the safe side?
