Underfloor heating
I just fixed our 240v electric under floor heating as a rat chewed through some of the cabling. The heating elements appear to run at 12v, probably explains why the rat did not get zapped :mad:.
The system you've linked to appears to be 11amps per square meter. :oops:
A friend fitted water-carried underfloor heating to his mobo (steel build) during a total strip-down.
Unless having the boat apart anyway I'd wouldn't go that way. If electric you'd need shore power to it properly, but if on shore power you'd have other easier and cheaper options.
Or one of the famous diesel air heaters.
