Carmel2
What solution should I use to clean a outboard carburettor in a ultrasonic bath?
I would try detergent and hot water as a first try. Many of the commercial fluids seem to contain a seaweed extract plus citrus fruit concentrates. I have used the latter for grease cleaning and it is remarkably effective and safe.
Here is a data sheet for another, not much of them lying around the boat! http://www.allendale-ultrasonics.co.uk/docs/ultra/us-so-car-solution.pdf
I use a truck wash detergent in mine, as it holds approx 50 litres of water
Stupid question. Where do you find a bath suitable for a carb? The ones I've found seem to be for jewelery and other small items.
I would be very careful using kero or A1 in a heated bath. Both have a flash point of around 38C, so above that there will a flammable vapour cloud above the bath. Aqueous with detergent seems much safer.
