JumbleDuck
My crew is budding Pi hacker and would like to play around with OpenCPN. Is there any way of getting UKHO charts to suit? I though the VMH ones might work, but I see that they are Windows only.
Many thanks. Any less convoluted and dodgy-looking sources?
.Many thanks. Any less convoluted and dodgy-looking sources?
Think Ocharts have close links to the openplotter project. But definitely not dodgy. Just released is a USB key so you can share between machines instead of only having one machine and one backup..
Relax! O-charts are not dodgy. They have formal agreements with all the HO's whose charts they offer. AFAIK the scheme was largely developed and set up by Dave Register, the OpenCPN lead developer.
You could try changing the chart object scale factor in the user interface options to increase the sounding font size. Works with cm93 vector anyway.Likewise I use them on opencpn. The only problem I have is that I can't make the depth figures big enough to read.
I have a laptop with vmh on standby sometimes if I'm not sure.
Sounds very likely that it's hardware problem your end. The openplotter image works.Coming from the nice, easy world of Xubuntu on desktops and laptops I am constantly amazed at what a bloody pain everything to do with the Raspberry Pi seems to be. Still, I suppose it's a bit unfair to complain that a hobbyist computer is fit only for hobbyists.
Installed Raspbian.
Added correct repo to the sources.list
apt-update && apt-get install opencpn
Worked just fine.
Is OpenPlotter raspbian based?
Maybe dodgy card, dodgy power? But very likely the issue is your end.
Installed Raspbian.
Worked just fine.
Did you try the openplotter image? Everything preinstalled plus the wonderful signalk.
http://www.sailoog.com/blog-categories/openplotter-rpi
Either just copy the noobs files onto a blank sd card (or usb pendrive is a PiB+) or burn the img using something like win32 disc imager.
https://sourceforge.net/projects/win32diskimager/
The majority of Pi problems seem to stem from a power supply which isn't up to the job, draws little compared to what it can do but the power draw spikes now and then. The Pi itself and the software are well up to the multitude of very useful jobs it can do onboard, can't think of any out of the box software that comes close.
