two stroke oil in a fourstroke?
realslimshady
31 Jul 2007
Andover
I've got a couple of gallons of 50-1 two stroke mix in the shed, surplus to requirements as I sold the outboard...will it be ok to put it in the fuel tank along with,say,20 gallons of straight fuel? Seems a shame to throw it away.
Chuck it in mate
Be ok
Presuming the boat has not got a diesel in it.
Innit!
Or if you are nervous about it
Chuck it in yer motor next time yer fill up
Same caveat!
No worries, probably do the engine good, as long as you do mix it with plenty of straight fuel, or the weaker mixture, could cause some overheating. But only mildly.
I empty any left over outboard (50/1) fuel into the empty car at the end of the season, then dilute it with straight fuel, with a fill up.
Takes away any chance/temptation of using stale fuel later.
If you chuck it in the car, does it not knacker the Catalytic converter up?
In large quantities it would probably not be good but we are talking about 200ml of oil in 10 ltr of fuel. Chuck it in the car when the tank is nearly full and the dilution will become something like 250:1. Once a year this shouldn't cause a problem. My car burns more oil than 200ml of oil a year anyway :D
You might notice a bit more smoke than usual, and if you spend ages idling the plugs might get a bit of oil on them, but it will soon burn off once you give it some welly :)
Yes I agree, it'll be fine if well diluted. I've done it often
Probably diluted, be about the same as three shots of redex!!
