Norman_E
I have just had to do some work on the boat and found two horrors.
Number One: I have two large filters, one filters the grey water from the galley sinks to prevent debris entering the pump that directs the water into the grey water holding tank. The other filters seawater to protect the fridge compressor cooling pump. Both have clear plastic domes over the stainless steel mesh and cream plastic bodies. They bear the logo of an American maker, but are made in China. They also say, not for use with alcohol. They should say not for use with water, because both proved hard to unscrew to clean the mesh, and completely impossible to screw back together. The reason: The cream plastic swells when wet! After two days drying out the diameter of the male threaded cream part has reduced by 2mm, and the two parts can now just be screwed together.
Number Two: The Vetus bow-thruster worked intermittently during our month long cruise, and finally failed altogether. The Reason: The Vetus supplied cables to the remote switch are made of domestic copper wire which has all gone black and no longer makes good contact at any of its connections. With 13.28 volts at the thruster end, I measured 10.9 volts at the helm switch end of the cable and less than one volt at the switch itself.
I spent a wearisome day getting some proper tinned cable through various ducts to get it working again. Really Vetus should no better than to supply ordinary copper four core cable.
