MedDreamer
I constantly read on here that manouvering with two engines is much easier than one but I am confused about the correct method with twin sterndrives.
As I understand it, if i had shafts rather than drives, I would use the same technique as a tank driver, rudders straight ahead, setting one engine in reverse and the other in foward for close quarter handling. I have also seen on here that this is not the way to do it with outdrives as the legs are too close together and it won't work effectively.
So I have been told that with outdrives you DO use the steering wheel and control the boat using whichever throttle is on the outside eg turning to port use the starboard engine and visa versa.
Can't get to try anything until next visit in January but would appreciate any tips you may have
thanks
Martyn
PS
on't tell hlb but if I do get in a mess I have a bow thruster as well.
thanks
Martyn
PS
