I would appreciate some advice on people's experiences with setting up a twin-headsail system for downwind sailing.
I would like a balanced alternative to using a spinnaker on it's own (ie no main), and such a system would seem the only realistic choice for a sloop-rigged boat.
The desired outcome would be something like twin 100% jibs (about 600 sq ft in my current boat). This seems quite adequate to me. The sail also matches my current spinnaker pole length - so would leave me requiring another sail and pole (ie half the cost of a complete set of gear).
My current set-up is very conventional with a standard furlex with twin-groove luff. I have a normal set of spinnaker gear.
I would particularly like advice on how to set the second sail when you have roller reefing on the forestay (block on the swivel, different foil?), and how easy it proved to be to set, reef etc.
Further, is there any issue about the load placed on the forestay/roller? This is a lot of sail area (much bigger than a no.1 genoa), and is likely to be left up in stronger winds than a spinnaker might be.
thanks
Further,
thanks
Further,
