Stewproud
New Member
Has anyone suffered a very premature failure of the above gearbox. Mine is fitted to a Nanni N4.60 (one of a pair) and was replaced in November 2015 after hitting a bag and not replacing the damper plate soon enough. I did only a few hours in 2016 due to family bereavement and no hours in 2017 due to open heart surgery. So this year during post refit trials it was found that the port gearbox was getting hot. On examination there was metal in the oil and the bearing shells are loose in the casings. One bearing runs rough and wear is uneven. The engineer thinks that the bearing(s) are faulty. The gearbox has done 62 hours!!!! Anyone else had such problems? If there was a batch manufacturing problem I may get some recompense from the distributor, retailer does not want to know. All cooling circuit is fine.
