Carioca
I "DIY marinised" a pair of MWM 4- cylinder lorry turbo diesels rated at 145 HP @ 2600 rpm. The injection pumps were re-calibrated to generate 170 HP @ 2600 rpm to avail of the added benefit of the after-coolers (sea-water cooled).
The problem: Starboard engine is fine but port is definitely underpowered over the whole rpm range, say by some 15 - 20 %.
I have made the following observations:
1. Port engine temp. gauge goes up quicker than starboard´s ; identical cooling systems, raw water pumps, raw water flow etc. and both heat exchangers were recently refurbished and cleaned.
2. Port engine turbo boost is some 10 - 15 % LOWER than starboards - at 2300 rpm, for example, port turbo makes 0,6 - 0,65 bar versus o,75- 0,8 bar on starboard; both turbos went through a complete overhaul recently.
3. Port engine sounds rough and nosier, while starboard is smooth.
4. The props were recently examined and nothing odd was found.
Extrapolating to my (limited) experience with petrol engines in cars, could it be that the injection timing on the port engine is retarded ?
Would welcome help on this subject.
