superheat6k
So in 2016 I fitted some lovely turbo boost pressure gauges when I refurbished the dash panel. So today I finally installed the senders. Both gauges seem to work and the pressure initially drops then as I increase the revs the manifold pressure does increase a tad, bit this is at no load.
So assuming I am underway and under decent power, what manifold pressures should I expect to see ?
Cummins 6BT5.9M.
Thanks.
Cummins 6BT5.9M.
Thanks.
