Trying to change coolant on Yanmar 3GM
dart
30 Sep 2003
I’m trying to change the fresh water coolant on my Yanmar 3GM. There seem to be 3 drain plugs with pipes going down to the bilge (2 on one side 1 on the other). When I open the cocks nothing comes out (the coolant is full!)
Any ideas what I could be doing wrong?
Thanks Chris.
steve28
19 May 2003
Cornwall
www.falmouthgypsy.com
most of the time the drain cocks or clogged up i always had to unscrew the plastic bung(dont loose it like another forumite!) then using a slim flatbladed screwdriver press and turn in the hole and you will find normally grit and rust will come out. once its running its fine and you can replace the bung to allow it to run down the tube.
I have always used antifreeze in mine and have never had any probems since.
It could be what the other poster has mentioned as well.
steve
dart
30 Sep 2003
Thanks very much all, that all sounds good. Will give it a go and report back /forums/images/graemlins/smile.gif
Aeolus_IV
24 Apr 2002
East Sussex
I can see that I am late to this one ... I did this on my 3GM30F at the last service, I needed open the cap on the heat exchanger to allow air into the system. It poured out at that point - the plastic tray I had under the engine to catch it all was nearly too small.
But all's well, that ends well.
I found that it took some time for the engine to circulate all of the air out the system (especially as I had just plumbed in a calorifier), so it is worth checking the level before you start the engine (while its cold), just in case it needs a top up.
Regards, Jeff.
