Movutomu
New Member
I am having problems with a VDO viewline tachometer - can anybody advise??
The boat is a vintage Freeman with a basic petrol engine circa 1965 - the original tacho being a dodgy old Smiths. This I replaced with a new VDO viewline tacho which receives pulses from the negative side of the coil just above the points. Immediately the engine is switched on and ticking over the needle on the VDO swings straight to show max full revs - 4000 rpm - but a handheld tacho reader confirms the expected 600 rpm. I have checked and rechecked the dip switch settings and wiring to be correct according to the supplied installation sheet.- and any contact with VDO simply redirects me back to this. I have also tried another VDO tacho with the same result so the instrument would seem to be ok - the problem must be in the installation. Can anybody help ??
