trimming doorways
Phoenix of Hamble
28 Aug 2003
East Coast
mishapsandmemories.blogspot.com
I wondered if anyone new if any of the usual list of wood moulding/trim suppliers offer parts large enough to put a trim all the way around a door way?
Its one of the usual shaped doorways.... rounded at top and bottom, about 5 foot high and about 3 feet wide..... and I got round to thinking that I've never seen trim/mouldings of that sort of size...... I guess the only difficult bit wll be the radius for teh top and bottom... regular U shaped trim will do the sides OK.....
Advice/ideas welcomed....
As has been mentioned previously in this forum, you can get softwood and mahogany trim from B & Q which should be OK. Teak is more difficult, Try KJ Howells and Son, Poole.
erm u-shaped wood trim ?
er u-shaped trim would be very small x-section.
The benjenbavs use double helping of L-section trim which works very well, eith butting one up against the other or overlapping.
Re: erm u-shaped wood trim ?
L section would do the trick.... my problem is that I can't curve L section (or U section) round that radius, so would need it pre-formed.....
The door 'hole' doesn't actually have a door in it, so the section need not be as small as you might imagine....
its an aesthetics exercise...
