AngusMcDoon
This is NOT the way to do it...
COuld the float just not be submerged? IIRC, they have a 'kayak garage' in the floats - maybe someone left the door open?
edit: googled it. Found this:
http://www.boatdesign.net/forums/multihulls/float-broke-off-trimaran-capsizes-29556.html
This particular dragonfly is discussed further down the page.
From the report it looks as though the damage from two previous collisions plus incorrect assembly of some parts caused a chain of failures.
quite impressive, through, how the whole boat stays afloat.....
IIRC dragonflies are meant to be able to sail with the floats folded in...
There have been 2 Dragonflies go over in the last couple of years because of the leeward float folding.
The one you are referring to was a DF920. It had been incorrectly repaired from former collisions causing a weakened float brace bar, and incorrectly maintained, where a block in the float outhaul line had been installed reversed causing the block to fail.
There were no injuries in either case and neither boat was lost.
But that was quite a few years ago
I consider they're not the most robust of multihulls on the market...
It was 2009, so 2 years ago. I'm not aware of any other similar incidents.
I agree. But to push performance limits you have to push engineering limits, which means (like aircraft) they have to operated and maintained correctly. A Heavenly Twins is a robustly built multihull that will forgive almost any abuse, but a slug to sail. You can't have both.
These boats are not for most people, but those who do own them generally know what they are in for before they buy them.
I'd comfortably sail anywhere 'off soundings' in the FX-9, but would now be 'twitchy' going out of sight of an RNLI station in a DF, new or old. And I have several sound reasons for that view....
And, having earned my crust in military aircraft for a couple of decades I know the value of reliable preventive maintenance on the airframes by qualified and experienced specialist engineers - and I also know the value of fully learning the lessons from predecessors' misadventures, so I don't repeat their misguided moments and suffer the same consequences.
