maxtorque
Advice, please:
Boat: Sealine Senator 240:
Had delisions of grandeur recently when I decided to replace the existing side cabin vinyl panels together with the dash panel at the base of the windscreen with walnut burr (like the stuff facing you in your luxury car dash board).
Spoke to Richard Poole @ sealine spares who told me of a process where they dip cut aluminium panels to shape and dip them in a chemical and laminate them. They turn out as 5mm thick burr panels. Anyway when the quote came through you can imagine the response when he said it would cost approx £800+vat for the 3 panels!!!
Anyway I went to plan 'b' which was to buy real walnut burr veneer (1mm thick) and stick it to 5mm marine ply, cost: £80!!!
Problem now is that the finished product needs "edging" to set it off properly. Because the panel is 6mm 'proud' of the cabin surface and looks unfinished.
Any ideas?
I did think of running trim around it (the stuff that runs around the edges of door hatches and lockers etc - this is atleast pliable to the extent that it can do a 180 degree turn in about a 3" radius!
Would be grateful for suggestions and where to get the stuff.
Many thanks.
WT
Any ideas?
Many thanks.
WT
