Trim tab Rams - Maker ?
superheat6k
10 Jan 2012
South Coast
Does anyone know who made these Trim Tab Rams from ~ 1990.
I need to source at least 2 of the internal stainless steel springs, plus various O rings, which should be straightforward. The springs are permanently immersed in seawater so the material needs to be pretty resistant.
An option would be to fit Bennett rams. These original rams spring return, so in operation the pump pushes the Tab down with the appropriate solenoid open. To raise the solenoid opens, but the pump doesn't operate, so the Tab raises.
Do Bennett rams operate in the same way ?
I believe the Bennett rams operate in a similar way, with a spring. This O-ring replacement leaflet might help.
Bennett Trim Tab Actuator O ring Sealing Kit w/ Instructions for 2 Actuator Cyl • $9.95
