Trim Tab Problem!
Alistairr
12 Dec 2002
North Ayrshire/ Glencoe
The Port trim tab wouldn't work at the weekend, and ideas what too look for??
Ok, the boat hasn't moved in a year, but i had it running a couple of months ago and everything worked ok then, but not the Port tab now.
Is this fixable without lifting the boat?
All advice greatly appreciated.
Cheers
Al.
AdeOlly
19 Dec 2004
Sussex
Hi Al - presume you have the Eltrim electric tabs. Check the connectors in the engine bay on the inside of the transom, may be a broken wire or a short. If not and your dash display lights up correctly, it's likely that corrosion has caused the motor innards to seize up. I've replaced no less than five over the years on boats I've bought and it's been the same every time. The little rubber bellows start to leak water and even sand into the unit which corrodes and seizes. They are sealed units and cannot be repaired. You buy them from the company that took over the RYB chandlery in Windsor, and they about £150 each /forums/images/graemlins/frown.gif Nor can you really replace without a lift out....
I hate the sodding things. One day I'll buy a boat with another make of tab.
The way to avoid failure is to replace bellows every couple of years....
Alistairr
12 Dec 2002
Yes they are Eltrim Tabs. On the dash i have 3 red lights, which is obviously the position it is jammed in.
So i presume you are suggesting its the motor then! /forums/images/graemlins/frown.gif
Bugger!
Thanks for the info,
Cheers
Al.
Alistairr
12 Dec 2002
IS the only place to get them from, the company that took over the RYB chandlery in Windsor that you mentioned??
And if i decided to change to the Automatic trimtabs, that i think Bennetts do, would both motors need changing?
Cheers
Al.
Alistairr
12 Dec 2002
The bennetts dealers are very very good however...
What, Would they travel to LL and fit it free of charge for me??? /forums/images/graemlins/wink.gif
Cheers
Al.
AdeOlly
19 Dec 2004
Sussex
They are now trading as Tingdene marinas Ltd, and they are the sole importer as far as I know. FYI I paid £142.83 + VAT back in January.
amf
30 Jul 2002
Surrey
www.crmtechnologies.com
You can get automatic trim tab controllers for Eltrim trim tabs as well. We used to have one on our S23. You need to find space for hydraulic pump and reservoir if you go the Bennetts route and if your S24 is anything like the S23 there is very little room or sufficient access in engine bay.
Mike21
10 Dec 2003
South Coast
Hi Al
Had trouble like this before, problem been only the switches on the control panel, it wouldn't move when pressing the individual switch, but would when pressing the switch to drive both tabs together.
pau1gray
8 Oct 2006
Plymouth
www.owlwise.co.uk
I sthe Eltrim the one that has the large black control box on the dash with a row of vertical green and red LED's??? I have that on my S23 but was really surprised when I found it was not attached to the dash last week - has something broken that stops it attaching to the dash???
halcyon
20 Apr 2002
Cornwall
You have a choice of, a relay, switch, fuse, joint fault in the control unit at the helm. You could have a broken wire, or joint failed in the cable to the transum. If the bellows have failed it could be the motor or gearbox in leg.
You need a multimeter and check voltage at the junction in the stern, check for motor voltage, if you need the cable id I have them somewhere.
Spares should be available via Sealine dealer, I also think one of two other people are handling them, if so a mail should appear.
Brian
Alistairr
12 Dec 2002
Hi Al
Tried pressing the both up/down buttons as well, and still nothing happened.
I will check all wiring and connection on our next visit, and then probably shell out for a new motor, as has been previously mentioned.
Thanks for all the info.
Cheers
Al.
