killick
My 1988 Sadler 26 has,some years ago,been treated for osmosis by the previous owner. It would appear as if he had only covered the hull in a thick layer of Nomosis and did nothing about the actual problem. I now have thousands of small,less than 10 mm,blisters which I am opening,draining,washing with fresh water and allowing to dry out before filling it with an epoxy filler and covering it with epoxy sealer,primer and antifouling. I find that the blisters that I open with a chisel weeps while those that i grind open with a small grindstone attached to a drill does not. Could it be that the heat generated by the grindstone seals the hole and prevent proper drainage? Any advice will be greatly appreciated.
